About air conditioner malfunction from Japan
#36
Thank you, everyone
Since it is spring in Japan, the temperature was between 15 ℃ and 18 ℃, but the message "ICE POSSIBLE" appears, so I suspect that the outside temperature sensor is out of order. Is it possible that the air conditioner is malfunctioning?
#39
Regarding the blower motor.
Maybe (tabun) this is mute question, but was the blower motor working before?
Also can you adjust/set the fan levels on the A/C controls?
You said "I have a gm tester" if you do and it is a GM Tech2 then you can test the blower motor. Go to "Body" -> "Heating and Air Conditioning" -> "Special Functions" -> "Output Control" -> "Motor Actuator Tests" there you can turn the Blower Motor "ON" which is 89% or "OFF" which is 0%.
Here is a video may help you check the blower motor.
xxbigjohn79xx
11-27-2018 08:19 PM
FLCHRIS
11-06-2009 11:04 AM
