2023 P0300 Code Engine mis-fire thread-2006 H2 6.0L
#41
the aftermarket tech2 also resets when you toggle the ignition. i believe the obd2 port cuts power causing a reset. you can look up an obd port pinout for vcc pin to verify power during ignition cycle with a test light.
#42
Dam, always something. Now that I'm having this issue I see a lot of others through searches, have had the same lost comm issues with the Nano/Tech2win setup. I reloaded firmware which worked for 1 guy. I'm hoping someone on here with the same Nano setup can help. Bad enough trying to fix the H2, but now got to fix the tool that was supposed to help fix the H2. Go figure.
#43
#44
It did it in most all screens but the crank relearn was worse where it wouldn't reconnect on its own. And it wouldn't allow me to complete the relearn which is a major issue for me.
#47
Thanks Neal, these images help to verify my port settings. I had to adjust them for my BRP/Evinrude software as well. I am also gonna try compatibility mode to see if it helps. My Win7 is 64bit Pro. Matching up settings now with yours and will try it in a bit. Honey do's got me for a bit. Daughter, SIL, Grandaughter will be here midday from Knoxville.
Everyone have a great and safe Thanksgiving and many thanks to you all helping me!
#50
