2005 H2 AC Compressor
going to replace my ac compressor.....question is ...has anyone removed the compressor out of the bottom underneath the truck or will it only come out the top.....i'd rather not disconnect the water lines if i can avoid that.....just asking what other have done here when replacing
thanks!!
jody
thanks!!
jody
jhall there was no cooling it was always blowing air just above ambient, the high-side low-side pressures were the same. I tried re-gassing but to no avail, pressures remained the same and of course no cooling.
The compressor clutch/belt started to smoke so I had to turn-off the A/C.
It turned out the clutch mechanism was shot, think the compressor must have had seized at one point probably from debris in the system.
No one here in the UK wanted to touch a Hummer so I was forced do job myself, my biggest mistake was buying cheap spares, particularly the condenser which leaked.
