2005 H-2 Dash Restoration
Old 04-01-2020, 04:39 PM
Rick-H-2's Avatar
Default 2005 H-2 Dash Restoration
Gentlemen, I'm in the process of trying to restore my dash parts on my 2005 H-2 (see attached photo). I have sanded all the dash parts with 320 and 1000 grit.. Also, I have cleaned all the parts using acetone.
I have not been able to get the areas smooth as I would like because of the rubber coating. I'm afraid that once painted, the marred and scratched areas will just fill up with paint and will show .
I'm wondering if all the rubber coating has to be removed and if so what is the recommended method. Also, if there is anything other methods that are better, I would greatly appreciate any any suggestions.or advise.
.I would like to think in advance to any of my fellow Hummer brethren that may be able to help.
Rick
Old 04-01-2020, 04:50 PM
Chrmer3's Avatar
I sent all mine out on my last H2 (yellow 2006) that had the same style finish as yours- I had it all coated to "Piano black gloss" the finish came out amazing and is a coating that makes it durable and nowhere near as fragile as the original or painted coatings...
I think total cost was around $500 however the difference in the interior was literally like a new vehicle dash finish, If you are keeping it- I highly advise going that route., I will see if I can find some pics..
Chris
Old 04-01-2020, 04:51 PM
mine did not have a rubber coating when i sanded mine. maybe the acetone is reacting with the paint or plastic. i just used a red scotch pad on the surface to prep it and washed it with soap and water.
Old 04-01-2020, 04:58 PM
Chrmer3's Avatar
pics of dash sent for permanent coating-
Old 04-02-2020, 03:07 PM
LoJac963's Avatar
The factory parts (non-silver or CF look) do in fact have a rubberized coating which is very thin. Unfortunately I think you are in for an immense time of hand sanding if you want to use those stock pieces. I would look into sanding drums/***** you can attach to either air tools or electric tools to make it go faster.
Old 04-02-2020, 07:45 PM
Rick-H-2's Avatar
Chris
Thanks Cmer, I'll post a photo when I'm finished.
Rick
Old 04-02-2020, 07:46 PM
Rick-H-2's Avatar
Thanks Bronx, I appreciate the info bro.
Rick
Old 04-04-2020, 04:02 PM
JAC-H2's Avatar
What is the paint code or aftermarket paint code for the OEM metallic finish. I want to restore mine when I take my dash apart this spring to replace the heater core.
Old 04-04-2020, 05:41 PM
I used rustoleum metallic paint and primer in flat antique nickel. I painted all the trim pieces with it but it is a tad lighter finish then stock but the texture is dead on. you can see the finish in the picture I posted above.
Old 04-05-2020, 08:35 AM
JAC-H2's Avatar
Thanks, that looks pretty OEM to me, nice job, now all you need is new radio and the dash will be perfect.
I have seen restored head units on Ebay.
Quick Reply: 2005 H-2 Dash Restoration
