05 Transmission Filter - New one doesn't fit
Thanks Hummerz, much appreciated.
I'll watch and check tomorrow, rain permitting.
I thought I'd selected the right depth.
So where is the depth measured, IE which end?
If the ACD part is for a shallow pan and my pan won't fit flush does that make my pan deep or shallow? ( Got nothing to compare it too)
You're gonna say "deep pan" wrong filter?
It measures 3" at the deepest area i.e. RHS internal depth.
Th new pan I bought with the drain plug was an exact match.... seems I got that right
Thanks hummerz as usual you've been a great help 👍
Managed to get a deep-pan filter one in the UK (amazement) should be here tomorrow, or Monday (Covid delays)
BTW I did measure the pan depth, but obviously miscalculated, your picture comparison says it all.
I'll rip the old filter apart and check for metal shavings & fragments etc when the new filter arrives (need it to compare)
The old pan looked like bellow, no big particles (you can see where I wiped my finger round):-
I followed your advice and did the Seafoam trip, not sure if it made any transmission changes, perhaps shifted gears a little more easily on the hills, but then perhaps I'm paranoid about noises it at the moment.
I watched your video and see I was being too careful, I should have just gone for it, may fabricate a tool while I'm waiting.
There was no way to remove the pan without removing the exhaust (not even with my claw hammer) even after removing the heat-shield and levering the transmission cable-bracket, I'd say it all came down to about 1/4" too much interference. Perhaps by levering and pushing more I might have got it out, but TBH removing the exhaust made access so much easier. Only spilled a small amount of fluid, the amount I measured was approx 4 quarts (4.7L)
Regarding torque, the manual calls for 8 ft-lbs (11 Nm) which seems a little on the low side, other sources list 12 ft-lbs (16 Nm) which perhaps seems more sensible.
As far as I can ascertain, lightly hand tighten, then torque in a cross-pattern, the manual just says "alternately and evenly" So based on similar ones I determined this sequence.
In other H2 videos they didn't seem to bother too much about the sequence and torque, am I being too careful?
Take all the bolts up flush, then give them a quarter or so, snug tight. Do not over tighten, you will see the gasket squeezing out if you do. Drive around to operating temperature, then park it and check for leaks/seepage, also check torque on the bolts. I've never used a torque wrench on the pan bolts, just gotta know the feel and make sure to watch that the gasket doesn't move outward. If the bolts are not tight enough, you will see seepage, however if the bolts are over tightened, you will need a new gasket. GL
