05 H2 coolant leak by cylinder 7 area
#22
btw, I ordered the head bolts and they are by DNJ. Anyone know if these are good replacements? I read a couple of reviews after I ordered them and some of those were not good. More were good than bad. Cheers
#23
Please comment if you see something I should be worried about
Has deposits but the walls look smooth.
This was during the removal process. There was quiet bit of coolant left.
At cylinder 7 where I saw the leak
Right side is cylinder 7
Right side C7
Lots of deposit but it looks solid.
Close up of that leak area. Looks like it’s been clogging up.
Let me know if you see any problem areas. Thanks.
#24
#25
Right side C7
Right side C7
#28
I use OEM fasteners almost exclusively unless I'm pushing compression then I'll move to ARP. I've seen DNJ in the aftermarket for some time but have never used them so cannot comment on the head bolts.
looking at the #5 & 7 piston tops it looks like you may have been getting some water in those cylinders for a little bit (carbon is washed).
I agree with Hummerz clean it good and inspect everything,
Neal
Neal
#30
Day ? Update
After taking a couple of days off today I got the passenger side head out. Next up clean up and I think it’s time to order new engine mounts while I’m at it. This would be the perfect opportunity to get this swapped as well.
few more pics
Extra coolant was cleaned up
Looks like something is clogged up top left gasket. And nice oil dipstick tube. It finally snapped but I have a new one to replace it with.
Overall doesn’t look too bad
few more pics
