05 H2 - additional work and progress
#31
@ bronxtek, nice.
update:
it's been brutal as far as heat in south Florid last few days so I'm tanned pretty good from doing all work in my driveway lol
anyways, list of items completed/installed:
1. Oil pan gasket and oil filter (coming in tomorrow). That was interesting and an experience. In the process I disconnected the front drive shaft from the front differential and by doing so, the ujoint busted to pieces, so picked up new one. Will probably replace the rear one tomorrow as well, make me sleep better at night.
2. New oil cooler lines
3. Power steering pump, bracket which I painted black, alternator. All back in place.
4. Cleaned up grease around the oil pan area, including the front bracket holding a couple of lines.
5. New steering shock.
next up, install the harmonic balancer, power steering pulley, belts, radiator, hoses and make final connections for the cooler lines. Oh also will be replacing the eltransmission cooler line between transmission and the radiator, it's about to bust. Will have to order the other transmission line as well, rusty bad.
almost there, few more days to get this puppy back to life. Thanks for all the advices. Youtube has been my best pal for months lol
Power steering area
It was nasty
Front of engine
Steering. I like the Bilstein matech front and back now.
Tomorrows assigment
update:
Power steering area
It was nasty
Front of engine
Tomorrows assigment
#32
The front grill has messed up chrome, any qay to fix it? Strip and paint possibly? Need some recommendations.
Work in progress. Finally cooled down.
This H2 is going to be bannanas
#36
One more delay but got everything in, except the air intake piece and need to fill up the power steering fluid. Coolant in as well, but I'm sure more will be required once I start the engine. Looking at the top of the engine, next up will be the fuel line and fuel injector rail, and I need to figure out which ignition coil is bad. Could be wiring harness too, we shall see. The truck ran well before all this work but had many leaks.
#37
Truck fired up on first turn of the key. I'm surprised there are no leaks, so that's a good sign. Temps and oil pressure looks good. Next up ignition coil, but will run the codes and make sure.
Refurbished the front differential cross bar.
New oil cooler lines ans new power steerting lines
#38
JUst wanted to give you props! That’s a huge amount of work. Awesome to see you complete it yourself and post pics.
and you did all of this in your driveway? No lift? No covered area? Just hand tools?
out of curiosity....how log did you have the h2 before you decided to do all of this work?
#39
so, over all, my father in law bought this truck back in NJ/Pa in 06 or 07. The truck had very few miles when he got it, maybe 20k tops. We got the truck when he passed with around 360k miles on it, so we had it probably around 5 years now with 2 years being sitting in driveway. Drives very nice, it is aged and definitely has been used. 412k right now and running. 2nd engine and second transmission. Still need to do the fuel lines, steering and front control arms and front wheel hubs. It's a ton of work for sure.
#40
Nice job! I hope you keep sharing.
I just replaced my (SUT) entire front suspension and steering (including box), both front brake lines, a parking brake cable, 2 front body mount bushings, reconditioned front and rear bumpers (off the truck). Still have a bunch to do, but considering it has been in New England its whole life, I'd say its held up pretty well.
It is such a nice riding truck, and I havent found a truck I like the looks of more, except maybe the H1/HMMWV.
cvendel
06-05-2019 08:24 PM
RoH2
53
06-17-2018 11:17 AM
