05 H2 - additional work and progress
Since I have all the time in the world right now, I have a little update on the current work on our 05 H2. It's been a lot of work so it's taking a lot of time, especially since most of the work I do on my own.
Anyways, here is the list:
1. Replacing all radiator Hoses with new silicone ones. Going with blue ones.
2. Replacing water pump with new fan clutch. drained the coolant already, probably more left in the water pump still.
3. New cerp. And AC Belts.
4. New pulleys.
5. Cleaning around the radiator, I just pulled leaves and debrie from a decade ago. It was nasty.
6. New oil and Trans cooling lines. Currently they are so rusty they would break to touch.
7. Cleaning around the engine, I'll try to remove and clean all the old grease out.
8. Installing RGB rock lights. Got a set of 8.
9. Install new tank straps. See pics for current state, yikes.
Additional work on the horizon:
10. New front shock/damper (Steering). Will go with Bilstein to match new front and back shocks.
11. Replace some worn out steering components. List to follow.
so far good progress. This baby will pull another 400k hopefully, who knows. Tomorrow taking of the hood so I can start getting busy. Working from the side sucks.
stay safe yall.
Rear tank strap. Holy, how did that hold all this gas? Replacing both straps. Surprised to see the new part are made in canada.
Work in progress. Its rainy season here in florida, i cover all the openings to keep stuff out of them (snakes, lizards, etc).
Lots to clean up and replace amd freshen up.
Before disassembly. Noticed the split lumen also needs to be replced. Its crystalized so much, it shatters to touch. Ill put that in the list to do.
Just for fun, its a rad rat aka corn snake. Good to have around and they have no venom. See those around all the time. Hopefully they wont nap within my truck frame.
Also good to have around. Black racer. Non venomous. Hes always around our truck lol.
4. New pulleys.
stay safe yall.
I have 2005 H2. Bought new radiator, Blue hoses, AC lines , cond, trans lines . Will repaint hood while i have it off to do the engine wood. Thanks for the gas tank strap check. will do that also. WV uses road salt in winter.
The straps were actually easy to install. I'm also looking for an aluminum radiator. The heat in Florida is no joke.
entire break system has been upgraded, master cylinder, all lines, all calipers and rotors and pads. Only thing left is the parking brakes, the lines are old and some lines have cuts. That's additional line item for me
Slow progress better than no progress. Been raining last few days pretty hard on the treasure coast. But I did manage to get the following out:
1. Water pump. Fairly quick to remove.
2. Power steering pulley. It was stubborn but came off after a long battle. Def get the tool for this job.
3. Power steering pump and bracket which hold the alternator as well. Fairly easy. Very rusty.
4. Noticed I need to replace the power steering lines, they are all trash and no better time than now to replace them all. Just ordered those up
5. Time to clean around the engine block and also start work on remov8ng front steering components.
break time lol
Yup rusty
Power steering pump
Water pump amd power steering pulley. Lots of rust on the water pump bolts and inside the unit itself. Not good. Pulley put up a good fight, it was stunborn
break time lol
Yup rusty
Power steering pump
