Who's using the 2" suspension lift?
I have found a few different kits and wondering who's running the 2" kit and are you happy with it?
What is the difference be between the $1800
Rubber duck kit vs just the spacers for $350-599
I see there is a ball joint angle shim. Is this nessasary with a proper alienment, or does it help with ball joint wear?
http://www.rubberduck4x4.com/s.....it-c86.htm
Can I get away with this, just the spacers for $350
http://bit.ly/12XcqrK
Also will this negatively affect the handling offroad at steep angles?
I am going to do a Cummins conversion and will also be running 40" - 42" tires. Thus, I will need the body lift to clear the engine, and the extra 2" suspension lift will be needed to clear the tires.
Can the factory suspension settings be maintained while using the cheap kit? Is the only difference between the cheap one and the expensive one the extra shims?
FilthyKings
05-17-2012 08:15 PM
triblk6spd
04-02-2011 10:57 AM
quadblaster240
09-14-2009 10:03 AM
schmegeggie
03-11-2009 11:33 AM
